TransEdit 4.0.7 beta doesn't open a stream
vramor
I've gave the TransEdit v4.0.7 a try with AVerMedia H831 USB tuner. The result was unsatisfactory - DVB-T/T2 streams were not opened. There is no problem with the opening the same streams via TransEdit 3.9.5 and DVBViewer 5.3.1 (Windows 7 Pro SP1 x64). The new version of TransEdit is very necessary because of its MPLP support.
An addition to my previous post. TransEdit 4.0.7 doesn't open a stream with AVerMedia H831 only if the driver version is 10.2.64.105 dated 18.03.2014. Everything is OK with the driver v10.2.64.93 dated 12.07.2013. So the AVerMedia is a reason.
