Problem logos
Residentcl
I tell him that is a problem for some time in DVBViewer.
In Problem 1.
as you can see, goes some irregular logos.
In Problem 2.
as you can see, stays focused logos are bigger vertically.
Here upload logos and a video sample of the problem.
support:
Have all Logos (*.png files) the same size 268x200 pixels?
Probably not and that causes your problem.
  • Like 1
But it is not possible any solution?
shrink all the photos, takes time.
The logos are lyngsat-logo with high resolutions.
Photos type E! Entertainment TV is DVBViewer problem clearly.
Now I have the solution for logos in Adobe Photoshop.
Thanks Tjod.
Upload another video.
The first part is:
An example that does not work out part of the DVBViewer OSD with channel logos.
The second part is:
By having the resized window, get the message across to the middle of the desktop screen, DVBViewer should display posts within the program and not outside.
