epg data doesnt match recorded show
aydan
Hi there,
I suppose this is just a minor mistake by Christian. I'm starting my recordings 5 minutes ahead of time to be on the safe side. But the Info that's saved for the recording always shows the EPG data from when the recording started and not from when the show I want to record started. The ultimate solution would be to save all relevant epg data while the recording was running.
Bye
Aydan
  • 1 month later...
hi
had same problem
i think it was the wrong gmt timezone that was set in config
that's not the problem. it really happens due to the record offset.
