viewer hang after about 2 days worth of recording
aydan
Hi again,
I have a rather serious problem with the viewer. I never managed to run recordings over a whole weekend (not with older versions either). Doesn't seem to be the length or number of recordings but rather the time spread that seem to cause the trouble. I tried to narrow it down as good as possible. I'm runninmg several recordings from friday afternonn till sunday afrernoon. Mostly on the same transponder (Prosieben/Sat1) with slumbermode at the end of each recording. but sometime after the last saturday recording at around midnight the program just hangs. It's happend three times already so it seems to be a systematic problem. I tried to do five recordings on five different transponders with slumbermode in between in one night and it worked fine. All powermanagement options have been disabled. I'm slowly running out of options here.
Bye
Aydan
Do you have a HT (Hyperthreading) CPU? If yes, tick "Use only first CPU".
Another suggestion: Switch off "Remember Last Data Channel". Should only be ticked if you use your SS2 for INet via satellite.
I have a AMD Athlon XP (have a look at my sig) and dont use skynet.
