Channel logos
Przemek211
What depends on assign logos to the channels? I thought it's channel name, but on some channels I can see that's not true.
Edited by Przemek211
It is the Channel name without the part in ( ).
And if there is no exact match the DVBViewer tries to find one that nearly match.
But the detection only runs if there is no logo in options > channel logos
Thanks for your answer.
But for example i have channels x and x hd. I have logo x hd.png, but DVBViewer shows the logo of x.png on both.
And other example, i had one channel which was replaced by other on same freq & PIDs and DVBViewer still shows the logo of old channel, even if i deleted the new channel and find it one again.
"options > channel logos"
Where is this? I can't find it.
channellogos.ini in ProgramData/CMUV/DVBViewer solved my problems
