amateuri Posted September 12, 2014 Posted September 12, 2014 (edited) Hi! I am using PCTV 292e tuner and tried few days to scan cable channels without any kind of success. The signal strenght is below the half. I am using Windows 7 64bit, I live in Finland, Turku and cable type is ClearQAM. TVCenter 6 finds all channels, but neither Windows Media Center or DVBViewer doesn't. Please help. Thanks in advance. Edited September 12, 2014 by amateuri Quote
Tjod Posted September 23, 2014 Posted September 23, 2014 please post a support.zip the we can make a test. Quote
Tjod Posted September 25, 2014 Posted September 25, 2014 Open the configuration folder and close the DVBViewer. Then replace the existing hardware.xml with this one hardware.xml And then start the DVBViewer and try a chennel scan. Quote
maxeen Posted December 1, 2014 Posted December 1, 2014 was it possible to do a scan after updating the hardware.xml file? Quote
TE3 Posted January 17, 2015 Posted January 17, 2015 Hi I have a similar problem. My signal-provider (Stofa Aalborg) changed the channel Pattern yesterday. Most of the channels are still working (they were probably not moved), but 7 including 3 very important, are missing. When I try a new channel scan, it says "No Hardware Available (in danish), and in the down-left corner of the dialog-box, it says (in danish: Aktuel enhed) I think: Current unit, but there is no unit mentioned. In "Options" under "Hardware" it list both my HDHomeRun tuners and my Cinergy card. I have attached a support.zip-file Hope you can help me Quote
amateuri Posted April 26, 2015 Author Posted April 26, 2015 maxeen: sorry for super late reply but no, it does not find any channels... Quote
GuranN Posted February 3, 2016 Posted February 3, 2016 Hi! I just found something interresting. In DVBViewer, at the channel search - type in the symbole rate as x1000 (I have 6875 and I typed 6875000) and suddenly all channels where there. It is working perfect - both HD and not HD channels :-) Quote
tpaasiala Posted March 29, 2016 Posted March 29, 2016 Just got new Hauppauge WinTV-dualHD TV Tuner and problem was that DVBViewer did not find any channels on cable-tv (I live in Finland, and network is ttv, www.ttv.fi). After some googling found out that adding this line to hardware.xml could help "<entry name="SRx1000">1</entry>". And yes, it worked DVBViewer now works just fine with my new tuner and finds all the channels. 1 Quote
Griga Posted March 29, 2016 Posted March 29, 2016 Can you please attach your hardware.xml? I would like to see the device ID in order to check if we can provide a general solution for this problem in future. Quote
tpaasiala Posted March 29, 2016 Posted March 29, 2016 (edited) Here you go. hardware.xml Edited March 29, 2016 by tpaasiala Quote
Griga Posted March 30, 2016 Posted March 30, 2016 Thanks. It will become a member our illustrious hardware database. Quote
tlipow Posted December 4, 2016 Posted December 4, 2016 Changing the hardware.xml in the configuration folder worked for me. Thank you Tjod. Quote
JPJ Posted May 23, 2017 Posted May 23, 2017 Thanks @tpaasiala! 1000x worked for my Cinergy T2 Stick HD Cabel! (hardware.xml attached) hardware.xml Quote
