recording service port forwarding
I've used DVBViewer on and off for a long while now. Only recently decided to give the recording service a go. Works great from the local network. I'm a little confused as to which ports I need to forward in the router to get access to the web view? I've tried all the ones within the configuration in both tcp &udp but I never seem to get in.
Any help would be greatly appreciated.
Cheers
Lee
With no-ip since they have disabled all accounts (microsoft incident) i can't access the webinterface anymore, but normally it should be port 8089, livestream: 7522, netstream: 2345
Do they all match up? Local and router? I've tried those ports..
Am I port forwarding to the actual pc the server is on?
Ie
192.168.1.141
I'm using a ddns.net address and can get into mediabrowser easily enough...
You need to change the Windows firewall rule to.
The in the setup added firewall rule permit only connections from the local network.
  • Like 1
@Tjod
figured it out after I turned the firewall off and it worked. saw that rule only said local subnet!
thank the bloody lord !! it was driving me crackers!!
now to try integrate this and mb3 into XBMC!
