Roghani Posted November 28, 2004 Posted November 28, 2004 (edited) Hello I have a SkyStar2 Rev 2.6C DVBcard. After installation I run Progdvb immediately. All channels (and their transponders) that I used in first run of the card are now locked (or blocked)! although other channels work . I should say most Horizontal transponders work well (not all) and most Vertical transponders don't work (for ex 12597 V doesnt work). How can I solve this? any answer would be appreciated in advance Roghani Edited November 28, 2004 by Roghani Quote
Hartwig Posted November 28, 2004 Posted November 28, 2004 Try to reset the card. deactivate and reaktivate it in the device manager. Quote
Klausing Posted November 28, 2004 Posted November 28, 2004 I run Progdvbhere is DVBViewerBoardthe card are now locked (or blocked)!There exist no lock since driver 4.28 !!! Quote
Roghani Posted November 28, 2004 Author Posted November 28, 2004 I activated and deactivated it but problem still exists. Quote
paulipm Posted December 4, 2004 Posted December 4, 2004 you may have a problem with your cabling or lnb check for co rosion Quote
