multituner option lost ?
lorvi
earlier version including "multituner" option that can record and watch different channelgroups at same time....now it's not work, why is that ? ( sorry my bad english) and how about option to record other formats? like divx/avi and mp4 and mkv ?
Nothing has changed, you can record (and view) all channels from one transponder (frequency) for each DVB tuner in you DVBViewer installation.
And the DVBViewer doesn't change the the video or audio codec during the recording. It is saved in the same format in which it comes from the TV station. Only the video container is slightly changed.
ok. is this problem only between HD-channels and "normal"channels ?
No but nearly all HD channels are only with other HD channels on the same transponder.
So for a HD and a SD channel you need mostly two tuner.
