DVBViewer freezs on some channels
perini14
I've just buyed a skystar2 card and installed DVBViewer TE. It looks great, but doesn't work very well for me. DVBViewer freezs when displaying Eurosport! When I press ctrl alt del, I see CPU performance is 100%. When I click the X on DVBViewer window to close it, the application closes, but the process DVBViewer doesn't terminate, it stays active and the CPU performance is still 100%. I then need to manualy end the process. And the problem continues: because DVBViewer stores the last channel that is viewed before closing, the next time I run DVBViewer, it displays Eurosport, and blocks. CPU is 100% and I can't move to another channel. So I'm stuck to watch eurosport only :D That's not bad, but I buyed skystar to be able to see other channels to ;)
So, I'm realy frustrated. I've installed and unistalled the DVBViewer a couple of times, but the problem remains.
Please can you help me!
Sorry for my english, I live in Croatia ;)
thanks
The last channel is stored in the file setup.ini. It can be opened with a text editor, so it is easy to find and delete or change the according entry - no need to re-install.
However, the basic problem remains. Is there something special about Eurosport? E.g. mono audio, while the other working channels are broadcasting stereo?
I can't find nothing special about Eurosport. I think that the problem is in my installed codecs, but I dont know how to fix it and where to look.
Can anyone suggest something ? :D
tnx
Yes, upgrade to DVBViewer Pro (15 Euro, not too much). Messing around with decoders is very hard with the TE, cause it doesn't provide a way to select them. The Pro version does.
Otherwise you'd need some knowledge about DirectShow, how to change its settings etc, and a good tool for that - e.g. the RadLight Filter Manager 1.4, that is available here for free - have a look at the plugins section of this board. But I strongly recommend *not* to use it, if you don't know how DirectShow works. If you are willing to learn, read this.
let us know which audiocodecs are on your system and we can give you ahint.
I dont know where to look. How can I find out which audiocodecs are on my system ?
Ok, here is the output:
MPEG2 Video Decoders:
DVD Express Video Decoder: 00600000
MainConcept MPEG Video Decoder: 005FFFFF
MPEG Audio Decoders:
MPEG Audio Decoder: 03680001
DVD Express Audio Decoder: 00600000
MainConcept MPEG Audio Decoder: 005FFFFF
