Recording details, genre and feature requests
TimoL
Does DVB RS save recording details in .mpg file? If yes, where? When I played with database deleting it deleting and rebuilding, once I noticed that for one recording all details appered even I had deleted details and log files completely. This is actually good feature, but why I can not see any of those details by explorer properties-details?
The details has genre selection, which is list by created someone. Can I make my own list or add new genres? The main problem with genre is that it is single item and not list. The movies are draama, draama/comedy, romance, romance/comedy etc. any mix of single genre. Is the list on DVB RS some standard?
Feature requests:
- Would be good, if I could choose genre already on recording definition time as I can set series.
- On the web interface I can do search with part of name. Would it be possible to search also from info? We get movie original name to info, but there is no way to search with it. Or if I choose all and then use browser search, I can, but the list is already slow now.
- In recording details I see field MinimumAge, but I do not see any place to set it. Could be also in the recording definition time.
If you enable Save EPG as File Info and the file is stored on a NTFS formatted Drive yes.
But the .mpg container format has no space for saving such meta informations.
Therefore DVBViewer/RS saves this information as Alternate Data Streams
There is "DVBViewer Recording Properties" in the Members Section to add the informations to the explorer. But it is discontinued.
The genre is part of the EPG and defined in the standard
http://www.etsi.org/deliver/etsi_en/300700_300799/300707/01.02.01_60/en_300707v010201p.pdf
(page 60)
No it is part of the EPG and that would mean that must be a possibility to edit more or less all EPG informations. And I don't see that happen.
(If you use XMLTV EPG you could edit the genre, before importing it via Xepg)
Same as the genre, it is part of the EPG.
There is nobody any more working on thee web interface.
So only if there is a web developer, how likes to spend time on it. And is able to tell Griga exact which changes at the server site are necessary and Griga finds time to change the server site. Only the is there a chance for changes at the web interface.
