mak73 Posted December 12, 2014 Posted December 12, 2014 (edited) Hi guys, I have a problem with Terratec H7 card (DVB-C). Free channels work fine. Most of the encrypted channels also work fine but few of them do not work at all - no picture, no sound. And I cannot see CAM menu. I.e.I can open it but it is empty. FloppyDVB card with the same CAM and smartcard shows all channels with no problem - shows all channels and CAM menu. I sow that other people have similar problems with Terratec cards and in some cases the problem is solved by using old drivers. Unfortunately I cannot find any old drivers for Windows 8 x64 to try. There is only TERRATEC_H7_Drv_Setup_1.00.07.601_XP_Vista_7_8_64Bit that can be installed on Win8x64. I tried both DVBViewer Pro 5.3.2 and DVBViewer TERRATEC Edition 8.3.4 - same result. support.zip Edited December 12, 2014 by mak73 Quote
