Cian Posted December 14, 2014 Posted December 14, 2014 I want to enable the Programme Delivery Control for the BBC satellite channels (where if an earlier programme over-runs the recording service auomatically extends the recording time to match). I have tried options but over runs happen so rarlely I don't remember which ones at this stage! Does anyone know which one actually works! Thanks, C. Quote
dvbrewer Posted December 20, 2014 Posted December 20, 2014 I don't think DVBViewer supports this, sorry . Quote
Tjod Posted December 20, 2014 Posted December 20, 2014 Enable Options > Recordings > Use PDC and Event ID EPG monitoring (if available), this should extend the Timer if necessary. http://en.DVBViewer.tv/wiki/Options_Service_-_Recordings Monitor for Recoding should be None (only use "EPG Running Status" if you are sure they you TV station is sending it correct, it will limit the recording to the time where the station is signalling it as running, if they stop a the signal a minute tu early your recording would be a minute to short) With the Tweak "EPG Event ID usage on timer handling" you can change the handling of that a little bit further. http://www.DVBViewer.tv/forum/topic/19629-recording-service-beta/?p=415594 Quote
