blaimer Posted January 5, 2015 Posted January 5, 2015 Hello, If I understand then is the product below in the link supported with DVBViewer that will use then the RTSP Network device? http://www.inverto.tv/products/product.php?id=264&typ=2 Has somebody already used it with DVBViewer and encrypted channels? Quote
Tjod Posted January 5, 2015 Posted January 5, 2015 The DVBViewer don't support client site decryption. So it will not work with encrypted channels. Quote
blaimer Posted January 5, 2015 Author Posted January 5, 2015 (edited) it is not possible to use the CI module of a BDA device for decrypting the channels? There are also plugins that provide a [removed, violating forum rule §13] for DVBViewer so that you can do the decryption by a card reader, will that be an option? Edited January 5, 2015 by blaimer Quote
Tjod Posted January 5, 2015 Posted January 5, 2015 it is not possible to use the CI module of a BDA device for encrypting the channels?You can only use the CI of a DVB card if you use this card to receive the channel you like to decrypt. There are also plugins ... so that you can do the encryption by a card reader, will that be an option? § 13 Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes. Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not. http://www.DVBViewer.tv/forum/index.php?app=forums&module=extras§ion=boardrules Quote
blaimer Posted January 5, 2015 Author Posted January 5, 2015 Ok, this will not be and option then. It’s a great technic to have minimum hardware and cables needed in your house to provide Live tv on every device. But without supporting encrypted channels it is not very useful for me. Quote
