fundom Posted January 20, 2015 Posted January 20, 2015 After a long period of inactivity I downloaded DVBViewer v.5.32 version ( I purchased it in March 2009). When using latest keyTool.exe from the installation, I get " Storing the key file failed " error. I am using Windows 8.1 Any solution? THX & REGDS Quote
Tjod Posted January 20, 2015 Posted January 20, 2015 What is the size of the .dvbvkey file? It should be 1.024 Bytes Is a other program blocking the KeyTool from writing in C:\Program Files (x86)\Common Files Quote
fundom Posted January 20, 2015 Author Posted January 20, 2015 (edited) It should be 1.024 Bytes well, the one with me is " 24 bytes" only, comprising of 16 digits. Edited January 20, 2015 by fundom Quote
Tjod Posted January 20, 2015 Posted January 20, 2015 Than your .dvbvkey file is damaged. If you don't have a undamaged version. Try describing you problem here (eMail or form on the page) http://www.DVBViewer.com/en/index.php?page=lost Give as much information as possible there, at least user name (from the license) and the name of the .dvbvkey file. Quote
fundom Posted January 20, 2015 Author Posted January 20, 2015 Have just done what you advised. THX Quote
fundom Posted January 21, 2015 Author Posted January 21, 2015 Thank you DVBViewer team for solving my problem so promptly Quote
