DVBViewer not recording after wake up from standby
Bjorn64
I have problems with scheldued recording after wake up from sleep mode.
It wakes up and start DVBViewer, but it does not recording anything.
It seems that the tuner is not started?
It works if I keep the PC on.
Have similar problem with Another setup, MCE + DVBLInk.
Is it a driver problem or anything wrong with the setup?
Setup:
ASUS Vivo PC
TTConnect CT2-4650 CI (USB connected) with latest driver 1.1.0.4.
Windows 8.1
DVBViewer 5.3.2.0
How do I turn logging on for scheldued recording, add -debug to string in Windows scheduler?
BR
Poste a support.zip to ensure that everything is configured correctly.
If you use the DVBViewer you have to disable all other serviced which using the TV card. No service from MCE or DVBLInk.should run in the background.
To add debug login for timer options > recordings > Scheduler Settings >> Command line parameters -c -debug
TV-server for DVBLink was running and I stopped it and then it worked.
So probably DVBLink "stole" the driver.
Hard to find that, as it is no problem when the PC is on!
It means that it's no good idea to have them installed/running on the same computer?
Can DVBViewer also block DVBLink and MCE if DVBViewer is not running, anything else left the background that can interfere?
BR
