Problem!
d2k
German: Hallo erst mal!
English: Hello guys!
German: Ich habe dieses Problem hier und weiß nicht was ich machen kann!
English: I have this problem and don't know what i can do!
Here it is:
"EAccessViolation raised by
instance frmMain of class TfrmMain at
02E547A6:Zugriffsverletzung bei Adresse
02E547A6 in Modul 'NeAudio.ax'. Lesen von
Adresse 00000004"
German: Was kann ich machen um endlich fernseh zu gucken?
English: What i can do, to look tv?
I have similiar problem if not the same:
6.12.2004 23:36:09 EAccessViolation raised by
7958E318:Zugriffsverletzung bei Adresse
7958E318 in Modul 'KERNEL32.DLL'. Lesen von
Adresse FFFFFFFF
I tried searching for that 'nero' in these forums but could not find a solution in english.
Adresse FFFFFFFF
That's not the "Nero" problem....
(But I don't know a solution. :bye: )
In addition program usually gives some error causing windows to kill that process after closing this error message.
This happened suddenly, I did install some programs in between but I already tried to uninstall them but it did not have any effect. Also tried uninstalling DVBViewer TE and reinstalling but that didn't work either.
With ProgDVB I can watch TV but it doesn't support my AirStar 2 card and so tuner doesn't work in there so it's quite unusable.
Any ideas? Need more info?
ps. should this problem be moved to a new thread?
There is no need. But I can split it from this thread, if you want. (Say me a headline...)
Yes, which version do you use (Driver, DVBViewer and Windows)??
And read this (no. 5) for needet infos: http://www.DVBViewer.com/forum/index.php?s...?showtopic=2210
(Maybe Christian or Griga can say something to this error message....??)
Ok, seems that I solved the problem. It was same kind of a problem after all. MP2 audio for registered to mp3lib when installing ffdshow. I used ffdshow audio filter configuration program to set it back to where it was (disabled).
I am using the 4.3.0 driver on my AirStar 2 and Windows 2000 SP3 with DVBViewer TE (don't know which version but the newest one from technisat's webpage).
Setup.ini
