Created duplicate timer
jirim100
Hello, I did the following:
- delete all EPG data, start EPG update, run autosearch timer
- then again delete all EPG data, start EPG update, run autosearch timer
after it are created two the same timers as shown in the following image (RS is version 1.30.1):
Edited by jirim100
Hello, I have exactly the same problem. Most autotimers (if not all) are doubled after some time of normal operations (no EPG cleaning, no new station scans, etc., just timer recordings and EPG updates). It was working fine until update from last beta to current release version. I live in Prague so use same Czech DVB-T transponders if that makes a difference for others.
