Shortcut to newOSD
I did it. I spend the money for the full version. :-)
Installation was ok. 2.3 Beta, osd and timeline 0.95. So now I want to get it all fully remote controllable and user friendly.
How can I create a shortcut for the remote (WinLIRC) to the new OSD Timeline EPG?
How do I know, that the program I selected for recording with the blue OSD key is successfully scheduled? Without going to the recorder section. In GotAllMedia for example there is a red dot in the corresponding block in the EPG, which is fine.
Regards,
MrG
At first you must select the new OSD in the Options. I think, you have selected style 1 and not the newOSD.
Guest Lars_MQ
ATM there is no way to create shortcuts for menuitems or plugins. This will be possible in the next version.
There is only a short beep (I think) when you send it to the PVR. The next version will show a red dot (or what ever) for scheduled recordings.
lars
There is no beep when scheduling via OSD. Only in Windows-programming the "Send to PVR" beeps.
Guest Lars_MQ
Ups then I removed it :bye: Well I'm shure I had a good reason for it (w00t)
Ups then I removed it  Well I'm shure I had a good reason for it
No app should beep without the option to switch it off...
Ok, that is what I assumed. So I am happily expecting the new version... :bye:
Why not make a selection which EPG should pop up when I push the EPG button? Classic or OSD?
Regards,
MrG
Guest Lars_MQ
I'm not shure what you mean. You mean Classic = the EPG window?
I wanted to suggest that triggering the EPG-Function (by remote) could either start
- Classic EPG (normal windows-like pop-up)
or
- OSD EPG (newOSD plug-in)
The configuration for that could be integrated in the DVBViewer Options dialog, lets say in the "EPG/Videotext" main section with a dropdown.
Just a thought... :bye:
Regards,
MrG
I have just installed NewOSD and OSDtimelne. What is the timeline supposed to do? when I select it from the OSD it just shows the path to the images folder with 'dummy' underneath.
Guest Lars_MQ
You have to enable the newOSD as the OSD-Skin in the DVBViewer options.
Then the timeline is suposed to show a epg-timeline similar to the one in the epg-window. :unsure:
Thanks I got it now, that newOSD skin is not easy to find, and didn't expect it to be a skin setting.
This is very nice, it gives DBViewer the remote control support it has been lacking, especially when controlling from infront of a TV rather than the PC. Great piece of work!
Its very nice. Heres the next one....
I've loaded up the DBViewer Beta, and when I hit any button (left right, up.... in timeline) the OSD goes off. I have now upgraded the OSD to version 95, and the timeline to v95 but the timeline has completely vanished from the OSD menu.
I'm sure I posted this before, sounds very familiar.
Guest Lars_MQ
Yes I know, but the DVBViewer wasn't designed in first place to have such extensive OSD-Support ;) We had to do some, well, workarounds B)
If you exit the OSD-Menu and enter it again, does it show up then? there is somewhere a little initialisation problem the first time.
But I'm not shure, if it's the fault of the newOSD or the DVBViewer. And to be honest, I don't think, I'm doing big investigations on this, cause the newOSD will be integrated in a much better form into the DVBViewer (the OSD-Demo ist the Beta for this new newOSD o:) ). And I spend all of my time making this baby work...
lars
Thanks for the reply. No, all my playing hasn't fixed it B) . I've seen your new baby, its very pretty. Can't wait to install it when its finished.
Thanks. you're doing some excellent stuff.
..When playing with Beta code, where do you want us to put stuff like this? in the beta's discussions, or in the bugs discussion forum?
Guest Lars_MQ
Please use this Thread for the OSD-beta reports. It's easier for me to monitor, if everything is in one place B)
thanks in advance, every input is welcome!
lars
