Support for Inverto IDL400s
Heathy65
Hi all,
Sorry if I've missed something obvious but I was hoping to get your app working with my SAT>IP 4 LNB Inverto Multibox IDL 400s unit. However when I install the app I don't seem to be able to add/enter the IP address of my IDL 400s unit. Am I missing something.
Thanks in advance.
  • Like 2
Options > Hardware > Add > RTSP >> select the device >> Settings > enter the IP address.
If you have no other Sat>IP clients, you can add 4 RTSP devices (and configure them).
The number of RTSP devices defins how many tuner the DVBViewer is using.
Thanks for you reply, however I can't see an "add" option in the Option > Hardware section.
I have a Scan Devices option (which finds nothing) and just OK and Cancel available (all other options are greyed-out).
Are you talking about the DVBViewer Pro 5.3.2 or about the DEMO?
Brilliant, thanks for your help.
I will upload a new demo version later this week. There are a couple more features inside this demo, since it will use the same codebase as the current DVBViewer since we did not published it yet. So for example the MadVR support will be part of it.
I hope that i will be able to publish it on Friday. Till then we will have to test this build.
Christian
PS: or you decide to get the DVBViewer and trust those who say that it will work with your hardware :)
  • Like 1
I've uploaded a new demo version earlier this sunday.
  • Like 1
