maikil Posted March 10, 2015 Posted March 10, 2015 I have a problem concerning the stopage programe (error 1279) but the problem that my account is actived. I have the error in the last DVBViewer Version ( 5.3.2) my english is bad... Quote
Tjod Posted March 10, 2015 Posted March 10, 2015 Have you download the DVBViewer setup with the same data you used for the installation? http://www.DVBViewer.tv/forum/topic/43909-general-license-questions/ Is the checksum in the KeyTool correct (compare with the data you received by e-mail after buying the DVBViewer Pro) Pleas post a support.zip Quote
maikil Posted March 11, 2015 Author Posted March 11, 2015 evyting is correct and support file support.zip Quote
Tjod Posted March 11, 2015 Posted March 11, 2015 What is the size of the C:\Program Files\Common Files\DVBViewer Shared\ .dvbvkey It should be 1024 Bytes Quote
maikil Posted March 14, 2015 Author Posted March 14, 2015 i have the same value (1024 Bytes) in old version i dont have this problem Quote
Tjod Posted March 14, 2015 Posted March 14, 2015 Remove the dvbvkey file from the DVBViewer Shared folder an add it with the KeyTool again. Download the DVBViewer setup again and installing it over the existing instillation. If that didn't help writ e eMail to the address on this site http://www.DVBViewer.com/en/index.php?page=lost an describe the siltation (inclined a link to this topic) and the user name you used to download the setup from the Members section and install the DVBViewer. Quote
