Plugins Question
Cian
Is it possible to isolate plugins so that they are only used on a particular group or satellite card?
Thanks,
C.
Mmm, it depends. If you write your own plugin you can implement a function to detect or query the current channel and card. So the answer to your question is: yes but it must be supported by the plugin.
Edited by dbraner
