dogknees Posted April 12, 2015 Posted April 12, 2015 I've just re-installed Windows and my apps and DVBViewer Pro isn't working as it did. Before the reload DVBViewer played all channels perfectly. Now all channels are very jerky or freeze completely. I've got 100% signal strength and have made no hardware changes. Windows was a clean install and is Windows 7 64 bit. If I switch from the default decoders in Options/DirectX to LAV I get better results, it doesn't freeze completely, but the picture has a lot of artifacts and the sound is choppy. Not watchable. Can anyone suggest anything to help troubleshoot the issue? Thanks Gordon Quote
