caretaker69 Posted April 15, 2015 Posted April 15, 2015 no go for me but I don't have the keyexe. running otherwise followed setup as shown no scan or device active. is keyexe. safe Quote
hackbart Posted April 15, 2015 Posted April 15, 2015 Did you downloaded the version from our server? Ignore the wizard, a channel scan should be done Inside the scan window. Quote
caretaker69 Posted April 15, 2015 Author Posted April 15, 2015 i downloaded demo from DVBViewer home page so no need to run keyexe. as it ask for why it doesnt show device even? Quote
hackbart Posted April 15, 2015 Posted April 15, 2015 I've updated the setup yesterday morning, there should be no longer a keytool request. The message can be ignored anyway. You have to open the Options and under Hardware you will see your devices listed. If you have only network devices you should add them also there. Quote
caretaker69 Posted April 23, 2015 Author Posted April 23, 2015 ok scan a few sats. from northamerica but most says locked do i use tools or plugins to unlock or need to buy registrtion? Quote
