Bjorn64 Posted May 5, 2015 Posted May 5, 2015 At the end of installation I get an message saying I shall run Keytool.exe. When I start the program I get an error message "Can not calculate media file, error 0x80040218. It was not possible to find any filter combination to render the stream". When I select a channel, there is only sound. I have made a factory reset of W8 on the PC Before installation. I have had DVBViewer installed before the reset. Maybe I have to make a clean up or what to do? I have tried to reinstall, but no difference. BR Quote
hackbart Posted May 5, 2015 Posted May 5, 2015 Ignore the Keytool message. It should be definitively gone if you redownload the demo. Anyhow the error message about the media file appears if you do not have any codecs installed which are required for decoding. Quote
Bjorn64 Posted May 5, 2015 Author Posted May 5, 2015 Yes, Codecs for Windows were not correctly installed. Fixed now. Thank's! BR/Bjorn Quote
