audio mute on minimize
I have just installed the latest version of Pro after carrying out a fresh install of Windows 7 on a new hard drive.
Previously I was able to mute sound when I minimised Pro but I cannot find this option on this new to me version. Is it still there somewhere?
The mute option on the menu doesn't work but thatvis probably more complicated.
Options > TV/Radio > Playback in minimized state >> stopped
Many thanks. Why I couldn't see this I don't know!
Is there a possibility to add the "CloseGraph" (Playback Off) while minimizing???
I think not.
Because that would cause many problems e.g. time shift will be stopped
And the DVBViewer would have to save a lot more informations or you would get a black screen after maximising or if you where watching a recording it would continue with live TV.
So a lot of work for nearly no benefit.
Ok. Thanks for the answer.
I will continue to use action id: DVBViewer.exe -x135 -x16382
