Moush Posted June 12, 2015 Posted June 12, 2015 Hello, I have installed a TBS dual DVB-S2 card, but it only shows a single Tuner A card. I have updated to latest drivers, and using Windows 7 64 bit. Any advise would be appreciated to get both tuners operating. Regards, Stephen. Quote
blasgl Posted June 12, 2015 Posted June 12, 2015 Show us your media devices in the device manager Quote
Moush Posted June 12, 2015 Author Posted June 12, 2015 Hello, Enclosed, Driver shows as a dual card, but in hardware on DVBViewer (and Windows Media Centre), only single tuner. sound/video and game controllers intel display audio realtex high definition audio tbs6982 dual dvbs/s2 bda tuners webcam pro9000 Quote
Griga Posted June 12, 2015 Posted June 12, 2015 For further investigation please use the TransEdit test version that I have attached here. Store TransEdit_Test.exe in the DVBViewer installation folder (where DVBViewer.exe is). Some functions are not available in the test version, but it provides extended logging. After having launched TransEdit_Test.exe, go to Settings -> Hardware and click "Detect Devices". Then close the test version. After closing the test version a log can be found in the configuration folder (see Info Menu in TransEdit) as TransEdit_Test.txt. Please attach the file here. Quote
Moush Posted June 12, 2015 Author Posted June 12, 2015 (edited) Hello, Thanks, enclosed. TransEdit_Test.txt Edited June 12, 2015 by Moush Quote
Moush Posted June 12, 2015 Author Posted June 12, 2015 Supplier TBS have indicated it may be a faulty card, as Tuner B won't initialise. I will keep you informed. Regards, Stephen. Quote
Griga Posted June 12, 2015 Posted June 12, 2015 TransEdit and DVBViewer call a system device enumeration function for KSCATEGORY_BDA_NETWORK_TUNER when scanning for devices, and this function only enumerates one tuner. No second tuner is visible in the log. There is no error that prevents finding the second tuner. It is simply not reported by Windows. Quote
Moush Posted June 12, 2015 Author Posted June 12, 2015 Can you explain your response please, is it likely that the card is at fault, or could there be a driver problem or conflict? Thanks for your prompt assistance to date. Quote
Tjod Posted June 12, 2015 Posted June 12, 2015 It could be either a driver or a hardware problem. The DVBViewer only communicants with the driver. So if the driver don't list the device for whatever reason the DVBViewer can't use it. So only TBS can answer you that question. Quote
