Files/Folders Management
athos
is it possible on HtpcHome→Pictures, Movies and Music insert for example in "Context Menu" the commands for files/folders management? (Cut,Copy,Create Folder,etc.)
Many Thanks
Athos
It is maybe possible via Commands.ini and some scripts.
​You crate a Commands.ini in the configuration folder
[RecCmd]
[PictureFiles]
[VideoFiles]
name=c:\programme\test.exe%%-o:“%f“
[MusicFiles]
​%% is used to separate parameters from the command
variables
%n: file name
%p: path
%f: file name and extension
%d: drive
%x: extension
German description:
http://de.DVBViewer.tv/wiki/Commands.ini
English description:
Members section > Sources > DVBViewer COM Interface > DVBViewer COM Interface.chm >> Interface ini_Commands
Many thanks Tjod for the tip.
There are ready-made scripts to do this?
For me it is difficult especially in the creation of folders because should appear even a virtual keyboard.
Not that I know of.
Commands.ini is a old option but rarely used.
