timeshift-folder
dds
I have downloaded the latest version of DVBViewer (full).
when I set the folder for the timeshift-recordings, the software does not use it.
Albeit what I choose, the files are actually stored in my user-directory (e.g. C:\Dokumente und Einstellungen\Daniel).
Bye
Daniel
System-properties:
Windows 2000 SP 4
Pentium 4
512 MB RDRAM
ATI Radeon 9200
HD Samsung 160 GB (UDMA)
Technisat Skystar 2 PCI
The 2.2 RC1 or the 2.3 beta ??
it was the RC1-version.
By now, the problem seems to be solved without any changes.
Maybe a reboot was required??
I installed the technisat-edition (from cd) first and then made the updgrade.
There is another issue that is solved by a shutdown:
When I change the timezone (default was 2, but I have 1), the changed time-settings only affects the onscreen-display but not the epg-window.
So I don´t know, if the recorder uses the new setting.
Maybe it would be good to display the current time in the recorder-menu, too.
delete EPG.dat
Next Time, please say the number of the version and not "the latest version", because the last version is the 2.3 beta :rolleyes:
