fatihb Posted June 26, 2015 Posted June 26, 2015 Hi, I've an existing DVBViewer Pro setup and able to watch tv. Then I've install DVBViewer Recording Service and try use direct stream over VLC 2.2.1. Also note that, althought I can see channel list and EPG on Kodi, I'm unable to watch any tv.. Please find attached support.zip support.zip
Tjod Posted June 26, 2015 Posted June 26, 2015 Run the Recording Service Setup Wizard and then try TV channels in the DVBViewer. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer Is it working in the DVBViewer?
fatihb Posted June 26, 2015 Author Posted June 26, 2015 I've follow the steps & able to play direct stream on VLC; but in order to make it work I have to follow these steps; On server; Start DVBViewer Navigate to the channel On client computer; open DVBViever Media Server web page Navigate to channel and click direct stream Open in VLC on server; Stop DVBViewer same steps also applias for Kodi. if I somehow close VLC, and restart Direct Stream nothing happens.. In order to watch, I've to follow step above. again.
