Channel Info - How to get it?
vramor
When I choose a channel from the Channel List I can see very useful and demonstrative information about the channel parameters during a few seconds like this:
Unfortunately I could not find how to get this window (open and close it) at any moment or to increase the time of its appearance. Please teach me!
OSD-OK [enter] opens the miniEPG
(OSD-Menue [Esc] opens the OSD menue)
and you can increase the time under Options > EPG > Show EPG Info on channel change duration in secedes
Thank you very much!
Settings > Options > OSD General > Menu timeout (seconds | 0=disabled) operates as well.
  • 4 months later...
A one question about this miniEPG window. The 'up' and 'down' arrow keys don't work for me when this window (miniEPG) has active. Usually this keys show nearest channels (don't switch to channel but shows it).
I can't find option how to set 'up' and 'down' arrow keys for this bahaviour.
in OSD menu 'up' and 'down' keys working but I want to select ch. from EPG by selecting it this way.
this workin in old versions of DVBViewer. Now I'm using latest 5.5.2 ver
thanks for any advices.
Edited by bozo
