Kiwi8 Posted July 1, 2015 Posted July 1, 2015 Suppose I have an existing recording timer with a selected channel. If I happen to rename the channel in "Channel Editor", will I have to edit the recording timer to select the edited channel so that the timer will proceed, or will it do this automatically? Thanks. Quote
Derrick Posted July 1, 2015 Posted July 1, 2015 ..I guess it will work. A timer uses a channel_id that doesn't contain the name. Quote
Griga Posted July 1, 2015 Posted July 1, 2015 The name is part of the channel ID. However, the channel recognition is fault-tolerant. Most likely it will still work with a wrong name. But the distinction gets less sharp. So it's always better to have the correct name. Quote
