annibal Posted July 2, 2015 Posted July 2, 2015 Hello everybodyI purchased a digimax humax and would like it to work perfectly with DVBViewerreceiver humax I brought the antenna cable and I connected to the receiver that I terratec I did scan channels and everything was fine except that I can only see the free channels Pay WIU me error and I says no receiverwhile in normal TV I see perfectly Pay WIUthere is a solution to this ??thanks 1 Quote
annibal Posted July 4, 2015 Author Posted July 4, 2015 perhaps you can help me solve this thanks support.zip Quote
Tjod Posted July 5, 2015 Posted July 5, 2015 As far as I can see, Humax Digimax Recorder is a DVR and not PC DVB hardware. What exactly are you trying to accomplish? As far as I can see, you are using a "Cinergy C/T2 Stick HD" which doesn't have a CI Quote
annibal Posted July 6, 2015 Author Posted July 6, 2015 hello thanks for your responsefrom the output of the decoder connect to the Cinergy C / T2 HD Stickif I connect it to the TV I see all those premium channels also since the decoder I installed a module cam with premium paper and I see all the premium channels from the decoder, but if I connect the antenna to the Cinergy C / T2 HD Stick see only free channelsI also see also pay channels since I have everything installed in decodersis there any solution for this ??thanks for your help ciao grazie per la tua risposta dall'uscita del decoder lo collego al Cinergy C/T2 Stick HDse lo collego alla TV vedo tutti i canali anche quelli premium dato che nel decoder ho installato un modulo cam con la carta premium e vedo tutti i canali premium ma se dall'uscita del decoder collego l'antenna al Cinergy C/T2 Stick HD vedo solo i canali freedovrei anche vedere anche i canali a pagamento dato che ho tutto installato nel decoderc'è qualche soluzione per questo??grazie per il tuo aiuto Quote
Tjod Posted July 6, 2015 Posted July 6, 2015 The Humax Digimax Recorder doesn't generate DVB-T or DVB-C output. Therefore it is not possible to get the signal via this stick in the DVBViewer. I don't know if the Cinergy C / T2 HD supports analog signals. If yes you could try a different program. The DVBViewer doesn't support analog receivers. A diferent thing would be a HDMI Grabber/Encoder/Capture Cards http://www.DVBViewer.tv/forum/topic/56510-grabberencodercapture-cards/ Quote
