krasno Posted July 17, 2015 Posted July 17, 2015 (edited) Hello I just downloaded the latest Recordingservice 1.31.0 beta, and my virus program block the .exe file form running. If I try to run it anyway,.. I get the message that there are insufficient system resources exist to complete the requested service. see attached screendumps Edited July 17, 2015 by krasno
Hansrh Posted July 18, 2015 Posted July 18, 2015 That's nonsens - file checked at Virustotal and out of 55 different virusscanners not one recognized it as virus : https://www.virustotal.com/sv/file/ffb13a25aeaabc860ff16a4046d6004fa38fdd45410e84dc570c9c8cfee49aca/analysis/1437209318/ / Hansrh
Hansrh Posted July 18, 2015 Posted July 18, 2015 I got another result! The file you tested was svc_setup_1.30.1.exe and not the new file svc_setup_1.31.0.exe If you check the new file not one out of 55 engines will report it as virus.
krasno Posted July 18, 2015 Author Posted July 18, 2015 I reported the problen to Avira, got no answer ( of course) but now I can install and run the file without any problems.. sorry for the big fuss!! ... it was false alarm. I didn't know that virustotal.com site, strange Avira report it virus free on that site, but not on my pc.. AND thanx for your replies !!
chris_ac Posted July 25, 2015 Posted July 25, 2015 Hi there, just for information ... I got some messages from Norton Security (Win 8.1) as well and this was harming the installation - disabling "Auto-Protect" while installation was needed. //Chris
