Lord NOva Posted July 29, 2015 Posted July 29, 2015 Hallo, ich versuche die Android App DVBViewer Controller zum laufen zu bringen, was auch früher schon geklappt hat. Momentan erhalte ich die Fehlermedlung "fehler beim verarbeiten des xmls" wenn ich versuche die Sender einzulesen. Wenn ich die XML direkt auslesen möchte (http://192.168.2.21:8980/api/getchannelsxml.html?subchannels=1&rtsp=1&upnp=1&logo=1), erhalte ich: This page contains the following errors:error on line 1 at column 3543: Char 0x0 out of allowed range Below is a rendering of the page up to the first error. rtsp://192.168.2.21:554/h ttp://192.168.2.21:7522/upnp/channelstream/Logos/das+erste+hd.png?src=1&freq=11494&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11494,22000,9750,0,0,3,2,5102,5101,5100,10301,134,0,24,0,1019,1,-1&pids=0,18,5100,5101,5104,5102,5103,5106,Logos/zdf+hd.png?src=1&freq=11362&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11362,22000,9750,0,0,3,2,6120,6110,6100,11110,134,0,24,0,1011,1,-1&pids=0,18,6100,6110,6130,6120,6121,6123,6122,Logos/zdf_neo+hd.png?src=1&freq=11362&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11362,22000,9750,0,0,3,2,6320,6310,6300,11130,134,0,24,0,1011,1,-1&pids=0,18,6300,6310,6330,6320,6321,6323,6322,Logos/zdf+kultur+hd.png?src=1&freq=11362&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11362,22000,9750,0,0,3,2,6420,6410,6400,11140,134,0,24,0,1011,1,-1&pids=0,18,6400,6410,6430,6420,6421,6423,6422,Logos/zdfinfo+hd.png?src=1&freq=11347&msys=dvbs2&plts=on&fec=23&pol=v&ro=0.35&sr=22000&mtype=8psk&tnr=1,11347,22000,9750,0,1,3,2,6720,6710,6700,11170,134,0,24,0,1010,1,-1&pids=0,18,6700,6710,6730,6720,6721,6723,6722,Logos/3sat+hd.png?src=1&freq=11347&msys=dvbs2&plts=on&fec=23&pol=v&ro=0.35&sr=22000&mtype=8psk&tnr=1,11347,22000,9750,0,1,3,2,6520,6510,6500,11150,134,0,24,0,1010,1,-1&pids=0,18,6500,6510,6530,6520,6521,6523,6522,Logos/tagesschau24.png?src=1&freq=11053&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11053,22000,9750,0,0,3,2,5402,5401,5400,10375,134,0,24,0,1039,1,-1&pids=0,18,5400,5401,5404,5402,5406,Logos/einsplus.png?src=1&freq=11053&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11053,22000,9750,0,0,3,2,5422,5421,5420,10377,134,0,24,0,1039,1,-1&pids=0,18,5420,5421,5424,5422,5423,5426,Logos/einsfestival+hd.png?src=1&freq=11053&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11053,22000,9750,0,0,3,2,5412,5411,5410,10376,134,0,24,0,1039,1,-1&pids=0,18,5410,5411,5414,5412,5413,5416, DVBViewer, Recording Service und DVBViewer Controller sind die aktuellsten Versionen. Jemand eine Idee wie ich meine Channels reparieren kann? Danke! Quote
Griga Posted July 29, 2015 Posted July 29, 2015 Wie sieht das aus, wenn du auf dem PC, wo der RS läuft, die XML mit einem Browser über http://127.0.0.1:8089/api/getchannelsxml.html?subchannels=1&rtsp=1&upnp=1&logo=1 holst? Mit Firefox oder dem IE sollte das Resultat als XML formatiert erscheinen, was bei mir auch ohne Fehler passiert. Ist der Port 8980 in der von dir angegebenen URL richtig? Falls ja, musst du ihn in der von mir angegebenen Adresse entsprechend ändern. Der Default ist eigentlich 8089. Quote
Lord NOva Posted July 29, 2015 Author Posted July 29, 2015 Ja der Port 8980 ist von mir so eingestellt. Lokal mit dem IE erhalte ich: rtsp://127.0.0.1:554/h ttp://127.0.0.1:7522/upnp/channelstream/Logos/das+erste+hd.png?src=1&freq=11494&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11494,22000,9750,0,0,3,2,5102,5101,5100,10301,134,0,24,0,1019,1,-1&pids=0,18,5100,5101,5104,5102,5103,5106,Logos/zdf+hd.png?src=1&freq=11362&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11362,22000,9750,0,0,3,2,6120,6110,6100,11110,134,0,24,0,1011,1,-1&pids=0,18,6100,6110,6130,6120,6121,6123,6122,Logos/zdf_neo+hd.png?src=1&freq=11362&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11362,22000,9750,0,0,3,2,6320,6310,6300,11130,134,0,24,0,1011,1,-1&pids=0,18,6300,6310,6330,6320,6321,6323,6322,Logos/zdf+kultur+hd.png?src=1&freq=11362&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11362,22000,9750,0,0,3,2,6420,6410,6400,11140,134,0,24,0,1011,1,-1&pids=0,18,6400,6410,6430,6420,6421,6423,6422,Logos/zdfinfo+hd.png?src=1&freq=11347&msys=dvbs2&plts=on&fec=23&pol=v&ro=0.35&sr=22000&mtype=8psk&tnr=1,11347,22000,9750,0,1,3,2,6720,6710,6700,11170,134,0,24,0,1010,1,-1&pids=0,18,6700,6710,6730,6720,6721,6723,6722,Logos/3sat+hd.png?src=1&freq=11347&msys=dvbs2&plts=on&fec=23&pol=v&ro=0.35&sr=22000&mtype=8psk&tnr=1,11347,22000,9750,0,1,3,2,6520,6510,6500,11150,134,0,24,0,1010,1,-1&pids=0,18,6500,6510,6530,6520,6521,6523,6522,Logos/tagesschau24.png?src=1&freq=11053&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11053,22000,9750,0,0,3,2,5402,5401,5400,10375,134,0,24,0,1039,1,-1&pids=0,18,5400,5401,5404,5402,5406,Logos/einsplus.png?src=1&freq=11053&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11053,22000,9750,0,0,3,2,5422,5421,5420,10377,134,0,24,0,1039,1,-1&pids=0,18,5420,5421,5424,5422,5423,5426,Logos/einsfestival+hd.png?src=1&freq=11053&msys=dvbs2&plts=on&fec=23&pol=h&ro=0.35&sr=22000&mtype=8psk&tnr=1,11053,22000,9750,0,0,3,2,5412,5411,5410,10376,134,0,24,0,1039,1,-1&pids=0,18,5410,5411,5414,5412,5413,5416, also leider kein XML, scheint das gleiche verhalten wie mit Chrome zu sein, nur ohne die Fehlermeldung, bricht auch an der gleichen Stelle ab. Quote
Lord NOva Posted July 29, 2015 Author Posted July 29, 2015 Ich habe es hinbekommen! Das Problem war, dass beim Sender "Einsfestival HD (AC3,deu)" ein ungültiges Zeichen am Ende des Names war "ç". Keine Ahnung wie das da hingekommen ist, ich habe jetzt über den Channel Editor den Namen geändert und schon scheint es zu funktionieren. Danke für die Hilfe! Quote
Griga Posted July 29, 2015 Posted July 29, 2015 Mit dem Zeichen alleine kann ich es nicht reproduzieren. Da muss es noch mehr Datenschrott gegeben haben, der wahrscheinlich nicht als Zeichen darstellbar ist. Aber hauptsache, es funktioniert wieder Quote
Lord NOva Posted July 29, 2015 Author Posted July 29, 2015 Mit dem Zeichen alleine kann ich es nicht reproduzieren. Da muss es noch mehr Datenschrott gegeben haben, der wahrscheinlich nicht als Zeichen darstellbar ist. Aber hauptsache, es funktioniert wieder Da hast du vollkommen recht, in Hex steht an der stelle 00 C3 A6 Quote
Griga Posted July 29, 2015 Posted July 29, 2015 Gab es in letzter Zeit irgendwas, das auf die Senderliste eingewirkt hat? Einen Suchlauf oder so? Es könnten natürlich einfach ein paar Bits auf der Festplatte oder im Speicher gekippt sein. Aber ein Bug im DVBViewer oder RS, der sowas macht, wäre unangenehm Quote
Lord NOva Posted July 30, 2015 Author Posted July 30, 2015 also bewusst geändert habe ich nicht, auch keinen Senderdurchlauf gemacht. Ich weiß auch nicht wie lange ich das Problem schon habe, kann durchaus schon etwas länger her sein. Leider habe ich auch dazwischen den DVBViewer geupdated, könnte also nicht einmal sagen mit welcher Version das Problem zum ersten Mal aufgetreten ist. Wie auch immer, nachdem das Problem nur bei mir auftritt, wage ich jetzt mal zu behaupten dass es kein DVBViewer Problem ist. Quote
