DVBViewer & windows 10 error render
i migrate on windows 10 and in DVBViewer (5.3.1 and now 5.5) i have sound but not video (black screen)
in launch i have message: (french message)
impossible d'effectuer le rendu du fichier error 0x80040154 classe non enregistrée
i test to modify in option, directx , renderer/decoder, but no success
Edited by MagiX
hello evr custom render video does not work under Windows 10 black screens whatever codec under v5.5.0.0 DVBViewer.
Edited by dotsy
I have no real idea.
May only guess is a problem with the graphic cards driver.
I seem to have the same problem. Since moving to Windows 10, I get some playback, but it is jerky, with only the sound playing without issue
@southpaw83
proper codecs are installed?
(Microsoft has removed it's codecs from Windows 10)
Did a clean install of Windows 10 the other day and working ok for me
System
Intel 3rd Generation Core i7-3770k
Gigabyte SKT-1155 G1 Sniper M3 Motherboard
GeForce GTX 660
  • Like 1
@southpaw83
Which codecs are they? I reinstalled DVBViewer and went from there. I had chosen LAV Filter codecs
System
GeForce GTX 660
Was there problems before a clean install?
Tested before when i did the normal upgrade to 10 from Windows 8.1 via Windows update and it worked ok it's just that i like to do a clean install when a new OS comes out
  • 1 month later...
Hmm
With LAV codecs it´s works but i still having stutter on HD channels.. ?! :glare:
Intel Nuc 4250
Long time ago i used the PDVD12 codecs ?!
Any suggestions ?
I'm on Win 10 X64 and using MadVR Video renderer with LAV Video Decoder all runs smoothly on my Terratec S7 with DVBViewer Pro. Connected to Thor 0,8w, Sirius 4,8e, Hotbird 13e and Astra19,2e with Diseqc.
MadVR Video renderer did it :D :D :D
No! it not working as it should! Black screens somtimes & stutter. :(
CyberDVD codecs or ???
Edited by swordoski
  • 3 weeks later...
Kodi works :) But not DVBViewer.
It works with HD channels , but on some SD channels with h.264 it´s not working in KODI. Crazy about this :lbounce:
  • 4 weeks later...
Windows 10 and its mpeg codec... :mad:
My computer without DVD Player app from Windows store had this problem (stutter in Window Media Player with MediaFoundation). Needed to use LAV for all. (But problem with some app if MediaFoundation is disabled)
For some reason, buying the "DVD Player" fixed all these problems and finally not needed to use LAV.
http://www.meedios.com/EN/forum/viewtopic.php?p=120679#p120679
The behavior is different depending if you have upgraded a version of Windows that already had Windows Media Center. Or if you have a clean install.
Edited by skypichat
