eddymc Posted August 4, 2015 Posted August 4, 2015 ive updated to windows 10 but for some reason i cant open any channels? ive tried rescanning which went fine so no issue with the card? any ideas? Quote
darkstar2 Posted August 11, 2015 Posted August 11, 2015 I had a similar problem eddymc and found it was one of these (not sure which, but now working): o Soundcard needed the speakers unplugging and plugging back in as it 'forgot' I had 5.1 speakers connected. o Check Settings>Options>DirectX and look at which decoders are being used. Try downloading LAV decoders if you can't get the ones shown to work: https://github.com/Nevcairiel/LAVFilters/releases Quote
Herbiv4 Posted August 16, 2015 Posted August 16, 2015 Hello there, I have also upgraded to WIndows 10 and I have the recording service 1.31.0.0 installed. I had no problems prior to upgrading to Windows 10 but now I am unable to set recordings up via the EPG or indeed manually within DVBViewer. Each time I get an error "unable to reach recording service". I cannot even click on the on-screen button to record totally manually. The only way I can make a recording is to go to the web interface and set up a recording via the web browser with the DVBViewer software off. I have no idea what is wrong. Had no problems with Windows 7 Ultimate. 1 Quote
subminiature Posted February 6, 2016 Posted February 6, 2016 I have the same issue following upgrade to Windows 10 - "unable to reach recording service". At least you got the web interface working. Quote
subminiature Posted February 6, 2016 Posted February 6, 2016 I just re-installed the scheduler. I can now record from both now. Quote
