bzoley Posted August 9, 2015 Posted August 9, 2015 Hi guys! Could you offer me a remote control solution that work also if the DVBViewer in the background and not active the window? Now, i can control with my leadtek remote and own config app, but must installed the card, original software(s). The config app can recognise the "trfmmain" window and send the hotkey command, but fisrt make the windows as active then back for the other window. Sometime it visible for few msecs. So, can i use other device that simple, direct? I was read abouth imon remotes that can send command to an specific app, but I'm afraid from visible window switching. Undersandable my question? Thanks, bzoley Quote
