Nolcad Posted August 9, 2015 Posted August 9, 2015 Hi, I noticed that since some versions before, the following "glitch" (feature?) appeared: When browsing channels using + and - but staying within the timeout value (I do this to scan the EPG info on channels) and coming back to the initial one (when I did not find something better to watch), DBDViewer will stop the stream and "retune" on the same channel. This has the following annoying consequences: There is a pause in the audio and video playback The channel resets to the default language/subtitle values This was not happening in some earlier versions of the software. Is this a bug? Is this a side effect of a new option? Is there something to tweak for DVBViewer to behave as it used to do? FYI, I am using a DVBT PCI card in France (Cynergy HT PCI (MK II). Thanks a lot, Thierry Quote
