fxv1 Posted August 21, 2015 Posted August 21, 2015 (edited) Ultra HD Test SES on ASTRA 28.2E I can get a stream working via this test channel but it is very choppy, do I need a new receiver? The other HD Channels work fine, no frames dropped. Anyone having good results. If yes what device are you using for Freesat DVB-S2 My device is AzureWave AD-SP400 DVB-S2. Frank Transponder: 2.038Frequency : 12.441 GHzPolarisation: VerticalSymbol Rate : 29.5 MS/sDVB-S2Modulation: QPSK Edited August 21, 2015 by fxv1 Quote
Griga Posted August 22, 2015 Posted August 22, 2015 do I need a new receiver? Wrong direction. The receiver doesn't matter. The question is whether 4k HEVC video can be decoded fast enough on your PC. So you need a good video decoder (try the latest LAV Filters) and a very powerful CPU or a graphics card that provides hardware HEVC decoding. Quote
Clemens123 Posted August 22, 2015 Posted August 22, 2015 (edited) Important for this is the Graphics card: The best choices for this are: Nvidia GTX 950 or higher (960, 970, 980, 980Ti, Titan X) or an Intel Skylake build in GPU Those have a hardware decoder for HEVC build in. I think a non HEVC GPU in combination with a Skylake CPU will work as well, but I'm not 100% sure of this. A HEVC GPU with a non skylake CPU works of course. On the AMD side I don't know if the 300 Series / Fury (X) are capable of doing this. Off course an upgrade makes only sense when more UHD channels are available and if you use at least a 1440p monitor instead of FullHD (or even better a 4k monitor/tv for native UHD TV) Only the NVidia cards have an HDMI 2.0 output. (not the Skylake CPUs)(so if you would use a HDMI 2.0 based Monitor/TV you only choice right now is NVidia) Most 4k Monitors will have a DP input -> depends on the skylake motherbaord, some have an DP output. The Nvidia cards normally have an DP output. I don't recommend using a HDMI 1.4 for 4k, because you are limited to 30 fps. Edited August 22, 2015 by Clemens123 1 Quote
fxv1 Posted August 22, 2015 Author Posted August 22, 2015 (edited) Wrong direction. The receiver doesn't matter. The question is whether 4k HEVC video can be decoded fast enough on your PC. So you need a good video decoder (try the latest LAV Filters) and a very powerful CPU or a graphics card that provides hardware HEVC decoding. Thanks for the reply. Yes I have a R9 270X which plays youtube 4K VPG videos well enough. see picture here https://7b66d766-a-62cb3a1a-s-sites.googlegroups.com/site/soundsokok/tech-links/videos/4K%201.JPG?attachauth=ANoY7cqGZ6-z3XCqufdypPyaSfJ7kfVkJwMwtV9KaE4HuTb9WTJC3MZEPl4J6F49xkY7RTmnQCpFjj3Dsd7mQbD7LA4kvQBjwrrmYpZ4EnPEMkK3-4STAkZgAKDs33eTA2XWvjWpvEuEG2aAHgsi5qTkwyqQfLDT47NTaGa3nUR7Nso2lQOscTwrPzA7o_UUHLYWRDUf_yeuJ8NMpIxHquaAq8CY0EkKN_V9Fjqhyyrd19p1N-Ekzeo%3D&attredirects=0 I Have DVBViewer setup with LAV filters. My signal says 93% on Freesat and the stream goes up to approx 22mB/s at times on the 4K test transmission. Using DVBViewer 5500 and latest AMD CCC. Edited August 23, 2015 by fxv1 Quote
Griga Posted August 23, 2015 Posted August 23, 2015 Yes I have a R9 270X which plays youtube 4K VPG videos well enough Doesn't say much about the capability to play 4k HEVC DVB streams that are much more demanding. Your equipment doesn't look like being sufficient. Check the CPU load. Quote
fxv1 Posted August 23, 2015 Author Posted August 23, 2015 Doesn't say much about the capability to play 4k HEVC DVB streams that are much more demanding. Your equipment doesn't look like being sufficient. Check the CPU load. Hi Griga, looks like my CPU is maxing out due to my GPU being incapable of decoding HEVC. This pic explains: https://8618975c-a-62cb3a1a-s-sites.googlegroups.com/site/tecchie2011/dvb_pi/4K%2022.JPG?attachauth=ANoY7cqImqLGBMb9DPWcFG26Czv03kzRwyyzE1KK9lBoxmzvT4qdKiiDiBRen-NGCny9CGoGfuePI1vtUwzYQAYNWLpoASgDF2wA1Ztyby488CFQ5_xz620PQXQjYZjyheV2blbyjYYNdW9kJfo49GuJuBTOnOhoxzf7VptKh5lxJ5p8cs2kcp_wT69jK8VryViznadHvWFqSGq70UMPDWnr5kkmx0koVg%3D%3D&attredirects=0 Quote
awehring Posted August 24, 2015 Posted August 24, 2015 (edited) Important for this is the Graphics card: The best choices for this are: Nvidia GTX 950 or higher (960, 970, 980, 980Ti, Titan X) or an Intel Skylake build in GPU Those have a hardware decoder for HEVC build in. I think a non HEVC GPU in combination with a Skylake CPU will work as well, but I'm not 100% sure of this. A HEVC GPU with a non skylake CPU works of course. On the AMD side I don't know if the 300 Series / Fury (X) are capable of doing this. We must be cautious with our hopes for Skylake in HTPCs. Intel Skylake has a built in hardware decoder for HEVC 8 bit resolution. HEVC 10 bit resolution will be decoded with GPU acceleration. It remains to be seen how well this will work and which processors / iGP will be fast enough. This became clear with the presentation of Skylake at the intel developer forum last week (data sheet). Unfortunately HEVC 8 bit is more or less useless, as UHD live TV will be in HEVC 10 bit, as well as UHD BluRay. The UHD test channel from ASTRA is already encoded in HEVC 10 bit. In addition, Skylake has no HDMI 2.0 (necessary for 4K at 60 Hz) and no HDCP 2.2 support built in. HDCP 2.2 is the copy protection used for UHD BluRays and most likely for UHD streaming (Netflix, Amazon, etc.). HDMI 2.0 and HDCP 2.2 must be added by additional chips at the motherboard, which is possible, according to Intel. Intel has one, called "Alpine Ridge". It will increase the price of the motherboard by about USD 20.- (estimated by Anandtech). AMD has no graphics card with a HDMI 2.0 output connector up to now. Edited August 24, 2015 by awehring Quote
fxv1 Posted August 27, 2015 Author Posted August 27, 2015 (edited) 4K HEVC Encoder Accelerator Cards, I wonder if a decoder exists. http://www2.advantech.com/nc/newsletter/NCG/Video/videoProcessing.html Not sure when these PCI express cards will be available but interesting hardware. Anyone with any knowledge please share. Frank Edited August 27, 2015 by fxv1 Quote
Derrick Posted August 27, 2015 Posted August 27, 2015 ..do you want to start your own playout ? Quote
awehring Posted August 30, 2015 Posted August 30, 2015 professionell stream kart preis ich skystar hd 2 2 anzahl cı slot sie ip tv professionell ???? Quote
fxv1 Posted November 22, 2015 Author Posted November 22, 2015 Lately my sound has been problematic. For example when a programme finishes (eg BBC1), the sound is lost for about 10-15 seconds then it picks up again. I tried using different settings in the audio setup, no change. Rebuild playback always works. Any ideas ? I'm using optical to a SONY STR-DN860 Video is always fine. Many Thanks Modulation: QPSK Quote
