MPEG file requires autopadding ...
Klausing
Hello,
I have a mpg file and want make a SVCD. If I add this file to VCDEasy ,I get following message
" This MPEG file requires autopadding ... you may be unable to watch it correctly. Do you want to add this file anyway?":)
If i click on OK i can make the SVCD but i cant look it in the DVD player. ;) How can i disable this "autopadding?
On my pc i can look this file and everything is ok. Can anyone give me a hint to solve the problem with this file?
(I had recoded it with Tmpg and i have the problem again)
Thanks
Steffen
need your settings in TMPGEnc,or load a standard SVCD-Template
and look by yourself filedate and Template.
greetings Plubsi
thanks plubsi,
with a standard SVCD-Template it works.
