start up freeze
wazza_2
hi i have been having this problem for a while, every time I stat up DVBViewer on a pay channel it freezes and doesn't start up. I have to go to safe mode and change the channel in there then go back to my original DVBViewer. I understand that its something to do with my plugin but cant find any other way around it. I have uninstalled and re installed numbers of amount of times but cant work it out
TechniSat SkyStar HD2
The driver doesn't work under Windows 10 (applies to all AzureWave cards sold by TechniSat), and there will be no update.
You need to revert to Windows 7/8 or buy another card. Sorry, no better news...
thanks for the reply but it is working just takes about 5 attempts to get the channels on, had the same problem with windows 8 its as though something is conflicting at the start up so it ends up freezing. after about 5 times of starting up and knocking it off. if I go to safe mode and turn it onto a free channel it works so I no its something to do with my plugin but I have used this plugin for around 3 years just started happening about 5 months ago
If the issue is caused by a third party plugin you need to contact the plugin author or post in a forum where this plugin is supported.
