leijlo Posted September 21, 2015 Posted September 21, 2015 Hi, I'm trying to configure DVBViewer to work with the windows task scheduler, but even if a scheduled a record, the task is not present in the Windows task scheduler panel. I've configured username and password. What else can I do? support.zip Quote
leijlo Posted September 21, 2015 Author Posted September 21, 2015 reading log file I've found this: 21.09.15 15:50:53.264 Internal Scheduler 80070057: cannot create the job. TDVBScheduler.Add() It can depend that I'm using an hotmail windows account? Quote
leijlo Posted December 15, 2015 Author Posted December 15, 2015 Why no one answer in this forum? If I can't schedule record using windows task scheduler how can I do it? Quote
majstang Posted December 15, 2015 Posted December 15, 2015 Oh, man sorry for not getting any help! Lookup and download Recording Service and you handle all scheduling of recordings in the webinterface. Quote
defcon5 Posted April 22, 2016 Posted April 22, 2016 Hi I´m looking for help for this issue with Windows10 From I upgraded from win7 to win10 RS no wake up my PC from standby for recording timers The setup of BIOS is ok for S3 With Teamviewer or Logmein I can wake up PC without problems Thanks in advance Quote
defcon5 Posted May 9, 2016 Posted May 9, 2016 Hello Nobody have tested with win10 DVBViewer+RS wake up pc from suspend? Thanks Quote
Tjod Posted May 9, 2016 Posted May 9, 2016 I have tested RS (and DVBViewer + it's Task Scheduler support) with Windows 10 for wake up pc from hibernate and sleep. And it works here without problems. But there are many things in a PC (manly drivers) which can prevent a timer based wakeup. (don't confuse timer bast wake up with WOL, which Teamviewer is using that are completely different things. WOL works from soft off, which is not possible for timer based wake up) Quote
defcon5 Posted May 23, 2016 Posted May 23, 2016 Thanks Tjod With wake on lan no problems, works fine What kind of drivers? graphics, tuners, motherboard, may be my motherboard don't suppor win8 or win10 (problem is with both) on ly works fine with win7 Thanks Quote
