toch Posted September 28, 2015 Posted September 28, 2015 I have installed the DVBViewer for a couple of days before. I found my channels, but I am just able to view my free channels. I have a CABLE card from Digital Device : Cine Series CI Duoflex ( dual tuner with Common Interface ) I have included some screen shots from my setting. Can anyone help me with this? I am running Windows 10. toch https://www.dropbox.com/s/g67x2ixrc6l7ee4/view1.docx?dl=0 1 Quote
SimonP Posted September 29, 2015 Posted September 29, 2015 (edited) The fact that 'CAM Menu" is greyed out suggests that you're missing the software/driver for the CI side of things. Make sure you've installed everything that came with the card and maybe contact the manufacturer if you still can't get it to work? (Note: I've never used a CAM or CI so I'm not talking with any authority. ) Edited September 29, 2015 by SimonP Quote
Tjod Posted September 29, 2015 Posted September 29, 2015 In the screen shot a DVB-T tuner is selected a support.zip is a better information source. But for Digital Device you need to configure in the driver tool which tuner should use the CAM. And are you using the newest TV card driver? Quote
toch Posted October 2, 2015 Author Posted October 2, 2015 thanks for the feedback, after I switch on the CI module in DD settings I got a find picture for all of my shannels - thanks But I have a couple ( 3-4 ) channels which have no sound : Can anyone help me with this ? I try to change some setting in "the LAV audio decoder" without any sucsess Quote
Tjod Posted October 2, 2015 Posted October 2, 2015 Look during playback in settings > Filter > DVB Source What are the Audio Format Information and Audio State? Quote
toch Posted October 2, 2015 Author Posted October 2, 2015 I find the Audio state : nodata / unconnected I didnt find the Aidio format Quote
Tjod Posted October 2, 2015 Posted October 2, 2015 Than the DVBViewer didn't receive audio date. Make sure that the channel-list is up to date. Quote
toch Posted October 2, 2015 Author Posted October 2, 2015 I am missing one channel, so I think I have rescanned 3 or 4 times - but I try again Quote
toch Posted October 2, 2015 Author Posted October 2, 2015 tell me - do I have to remove the old channels first ? Quote
toch Posted October 2, 2015 Author Posted October 2, 2015 i have bin upgrade 20 times now. I cant find my missing channel ( 362000 / 6950 ) or no sound in the BBC channels or TV 3 - Norway Quote
