Znida Posted October 3, 2015 Posted October 3, 2015 Is it possible to copy Destription in Transponder list as channel name in Scanner? When I import m3u file, I have the names of channels in description, but when I scan it, only a few have names. Quote
Znida Posted October 3, 2015 Author Posted October 3, 2015 How can I import and use m3u in DVBViewer? Quote
Znida Posted October 3, 2015 Author Posted October 3, 2015 Is there no solution? Is only option to rename all the channels after I import them in DVBViewer? Quote
Tjod Posted October 3, 2015 Posted October 3, 2015 For the old DVB-IP TV (DVBViewer Pro/RS) there is no other solution, then enter it manually. If the Server isn't providing it properly. In DVBViewer GE and TransEdit 4.x there is the new TS streaming support. There are two solutions. In the DVBViewer GE dreg and drop the .m3u on the DVBViewer GE channel list. Or open it with TransEdit and select "Omit SDT and use description as channel name". It is intended to include the new TS streaming support in DVBViewer Pro and the RS in future. But that my take some time. There is no time schedule. Quote
Znida Posted October 5, 2015 Author Posted October 5, 2015 Thank you for your answer. Since I use Pro version and recording services for streaming to other computers I will have to wait for this feature. Quote
