How to update DVBViewer
RJC
I have version 5.3.2.0 on a Windows 8,1 PC.
How do I upgrade to a more recent issue?
I have downloaded the most recent setup.exe file , but when I try and run this nothing deems to actually happen.
Am I doing something wrong?
Fixed!
Well nothing worked whatever I did - tho' something was running in the background.
I have a different Anti-virus to that originally used and disabling that for 10 minutes cleared the problem!
I just wish some sort of indication was displayed with a clash like this.
Thanks for anybody looking @ this and sorry if obvious to you
Yes, but it's your anti-virus who should display a message "blocked XYZ" or something. How could DVBViewer setup display anything when it's blocked?
  • 2 months later...
version 5.3.2.0 is the most STABLE - win.10 x64 PRO
version 5.5.2 is horrible CRASH - win.10 x64 PRO
Remove crapware like:
Install K-Lite Codec Pack
Keep your system clean from unnecessary codecs, splitters and such. If you mess up your system too bad you will be forced to format and re-install windows.
  • 4 years later...
DVBViewer pro not have task "latest update" or search for update,version 7.0.1.2 ,why ?
