Encountered this error when viewing a SD channel in DVBViewer on Windo
Kiwi8
Hello, recently I upgraded from Windows 8.1 to Windows 10.
When I tried to view a SD channel in DVBViewer I got the below error. Will this problem be solved by a reinstall of DVBViewer?
Microsoft removed its MPEG2 codec during the "update" (operating system change).
So you need to install e.g. LAV Filters and configure the DVBViewer to use codec.
I see... thanks.
Btw should I use the 32 bit or the 64 bit of the filters?
32 bit for DVBViewer. Additionally installing the 64 bit version doesn't hurt...
I see... thanks.
