Easy way to switch default language on channels
videogamingtown
I'm currently on 19.2 and the default language on most channels is german, however there is a second channel available on a lot of channels that is english, is there any way to switch these to use the english language by default when tuning?, i would like this in the channel editor because i am also using recording service.
Move your preferred audio track, in the channel list editor ,via drag and drop an the first position.
  • 3 months later...
Its possible to defined several languages? Like
1) german
2) English when german is not avaiable
3) ... if English is not avaiable...
4) ...
The selection is only possible per channel. So you have to decided it on a pre channel basis.
