Remove DVD then restart DVBViewer causes error on startup
Geezerjem
Hi there,
I have recently been playing a DVD using DVBViewer as it seems to give the best results of the various softwares I have. However, I have now found a problem. I have found that this error message comes up when starting up DVBViewer if the DVD has been removed during or after DVBViewer has been closed down. This is a sensible message, BUT whether I press Cancel, Try again or Continue, it won't go past this message until some sort of disc ( either a a DVD or CD ) is inserted. I am now stuck with having to leave a disc in the drawer :-(
I was using an older version but have installed 5.2.2.0 now and it still happens.
If you want me to try things, please tell me.
Thanks,
Jem.
Ok, I have found a workaround. Untick 'Autoplay DVD's' under Settings --> Options --> Movies. It looks like ( to me ) once a DVD has been played, it tries to Autoplay even if it's not there. Pressing Continue or Cancel should let DVBViewer run, but doesn't.
Please note that this is a workaround, not a bug fix.
Thanks,
Jem.
I can't reproduce it here, but searching with Google for
dvd "there is no disk in the drive"
finds Youtube videos dealing with this problem, e.g.
https://www.youtube.com/watch?v=7khU0ZY9gBU
It shows how to apply a registry hack that avoids this problem. IMO the issue is more system related than DVBViewer related.
If you get a specific error message it's always a good idea to search it in the web.
