add channels to context menu in task bar shortcut
wmax
Good evening,
When right clicking on the DVBViewer taskbar icon there are (among other options) three german channels. Each provides a rapid start of DVBViewer with the selected channel.
This feature is really handy for fast testing my antenna without passing the favorites menus.
But since I do not live in Germany and I have also hardware attached for other satelites, cable and terrestrial DVB I would like to add some other channels to the context menu.
Can anybody help me how do this?
Thanks in advance!
  • Like 1
It is defined in the file jumplist.ini in the configuration folder. I would recommend the format
[Channel Name]="-c:[Channel ID]"
where [Channel Name] is up to your choice and [Channel ID] can be obtained from the DVBViewer channel editor -> right-click a channel -> Copy ID to Clipboard.
The result should look like
arte="-c:2359890582722586686|arte HD"
  • Like 1
Thanks for your prompt answer.
Tomorrow I will adapt jumplist.ini and report the results.
Good afternoon,
I edited the jumplist.ini file following your advise.
But after restarting windows and DVBViewer the context menu remained unchanged.
Is there a next step? Am I right that somehow the modications have to enter in the registry?
Bingo!
After editing the proper file the context menu showed correctly.
Many thanks! Once more I am impressed by the versatility of the DVBViewer software.
Note: By searching my harddrive for "jumplist.ini" in Explorer I also identified the proper file in "ProgramData/CMUV/DVBViewer.
